*rigid()
Creates a rigid element in HMASCII format.
*rigid (id type node1 node2 dofs)
HyperMesh HMASCII Command
id
The ID of the element (must be unique).
type
The element type.
node[1,2]
The node IDs of the element.
dofs
The degrees of freedom of the element (one digit for each degree, from 1 to 6, e.g., 123456 or 135 or 2).
None.
