*subsystemconfigurations()
Creates a subsystemconfiguration in HMASCII format.
*subsystemconfigurations (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the subsystemconfiguration.
name
The name of the subsystemconfiguration.
color
The color of the subsystemconfiguration. Valid values are 1-64.
To create a subsystemconfiguration with ID 100, name "my-entity", and color 1:
*subsystemconfigurations(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2020
