*subsystemsets()
Creates a subsystemset in HMASCII format.
*subsystemsets (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the subsystemset.
name
The name of the subsystemset.
color
The color of the subsystemset. Valid values are 1-64.
To create a subsystemset with ID 100, name "my-entity", and color 1:
*subsystemsets(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2020
