*rigidwalls()
Creates a rigidwall in HMASCII format.
*rigidwalls() (id, name,color)
HyperMesh HMASCII Command
Creates a drigidwall in HMASCII format.
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the rigidwall.
name
The name of the rigidwall.
color
The color of the rigidwall. Valid values are 1-64.
To create a rigidwall with ID 100, name "my-entity", and color 1:
*rigidwall(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2017
