*attributeentityarray2d()
*attributeentityarray2d (type rows columns value1 value2 ...valueN identifier behavior status solver)
HyperMesh HMASCII Command
type
The type of entity that is contained in the attribute (i.e. prop, elem).
rows
The number of rows in the array.
columns
The number of columns in the array.
value[1-N]
The IDs of the entities in the array.
identifier
The number of the attribute in the corresponding solver.
behavior
The behavior flag for the attribute.
status
The status for the attribute.
solver
The solver number for the attribute.
Incorrect usage results in an import error.
