*membersections()
Creates a membersection in HMASCII format.
*membersections (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the membersection.
name
The name of the membersection.
color
The color of the membersection. Valid values are 1-64.
To create a membersection with ID 100, name "my-entity", and color 1:
*membersections(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
