*alefsiprojections()
Creates an alefsiprojection in HMASCII format.
*alefsiprojections (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the alefsiprojection.
name
The name of the alefsiprojection.
color
The color of the alefsiprojection. Valid values are 1-64.
To create an alefsiprojection with ID 100, name "my-entity", and color 1:
*alefsiprojections(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
