*plotbounds()
*plotbounds (xmin xmax ymin ymax)
HyperMesh HMASCII Command
xmin
The x value of the lower left axis range.
xmax
The x value of the upper right axis range.
ymin
The y value of the lower left axis range.
ymax
The y value of the upper right axis range.
This command must follow a *plot() command.
None.
