*designpointsets()
Creates a designpointset in HMASCII format.
*designpointsets (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the designpointset.
name
The name of the designpointset.
color
The color of the designpointset. Valid values are 1-64.
To create a designpointset with ID 100, name "my-entity", and color 1:
*designpointsets(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019.1
