*designpointmethods()
Creates a designpointmethod in HMASCII format.
*designpointmethods (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the designpointmethod.
name
The name of the designpointmethod.
color
The color of the designpointmethod. Valid values are 1-64.
To create a designpointmethod with ID 100, name "my-entity", and color 1:
*designpointmethods(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019.1
