*independentdofs()
*independentdofs (dof1 dof2 dof3 etc)
HyperMesh HMASCII Command
dof[1 to n]
The value of the corresponding independent node degree of freedom.
This command must follow a *rbe3() definition. There must be as many dofs defined as stated in the *rbe3 command.
None.
