*constraint()
*constraint (id type locationid inputsystemid comp1 comp2 comp3 comp4 comp5 comp6)
HyperMesh HMASCII Command
id
The ID of the load (must be unique).
type
The type of the load.
locationid
The node ID where the load is applied (must be a valid node).
inputsystemid
The reference coordinate system of the load (must be a valid system or 0).
comp1
The value of the constraint in dof1 (-999999.0 for none).
comp2
The value of the constraint in dof2 (-999999.0 for none).
comp3
The value of the constraint in dof3 (-999999.0 for none).
comp4
The value of the constraint in dof4 (-999999.0 for none).
comp5
The value of the constraint in dof5 (-999999.0 for none).
comp6
The value of the constraint in dof6 (-999999.0 for none).
Constraint definitions must follow a *loadcollector() command.
None.
