poIPost ImportResultDefinitions
Imports the result definitions from an XML file.
post_handle ImportResultDefinitions filename
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, imports the result definitions from an XML file. Returns Success (0) or Warning (2) if the file does not exist.
filename
The name of the XML from which the definitions will be imported.
To import result definitions from result_defs.xml.
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client ImportResultDefinitions result_defs.xml
hwi CloseStack
Returns a warning if the file does not exist and sets error condition on the session handle. See session_handle GetError.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
