poIPost RemoveResult
Removes a result definition with the given ID.
post_handle RemoveResult id context notify
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, removes a result definition with the given ID. Returns Success (0) or and error code.
id
The result definition ID to remove.
context
A string indicating the context of the result to remove (scalar, tensor, vector, iso).
notify
Set to 'true' to trigger an event to update the browser, otherwise 'false'. The default value is true.
To remove the tensor result with ID 3:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client RemoveResult 3 tensor true
hwi CloseStack
Returns error code and sets an error condition on the session handle. See session_handle GetError.
Related Topics
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
