poIResultCtrl SetDisplaySelectionSet
Assigns a selection set for a given context on the result ctrl handle to display the plot on entities in the set. Note that this is only supported in async HyperView.
poIResultCtrl_handle SetDisplaySelectionSet context idstr
HyperView Tcl Modify
This command sets a selection set to the result controller for a given context which will be used to display the plots on those entities in the set.
context
The context for which display selection set is to be applied. Valid options include: scalar, vector, tensor, and iso.
idstr
The string which fully defines the selection set. It is a locator string which may be a pool ID string.
To assign a selection set with ID 5 to the result control and plot the result only for set 5:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle resctrl_handle
resctrl_handle SetDisplaySelectionSet 5 scalar
set rid [window_handle AddResult myplot scalar]
resctrl_handle PlotResult $rid scalar
hwi CloseStack
None.
