poIScalarDefine SetAverageFactor
Sets the nodal variation factor. Specify the threshold variation level above which nodal averaging should not be carried out.
poIScalarDefine_handle SetAverageFactor f
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, sets the nodal variation factor, which specifies the level above which nodal averaging should not be carried out.
Note: The result definition can only be modified if it is not cached.
f
The threshold level between 0.0 and 100.0.
To set the average factor for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetAverageFactor 35.0
hwi CloseStack
None.
Related Topics
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
