poIScalarDefine SetValueFilter
Sets the value filter values.
poIScalarDefine_handle SetValueFilter from to
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, sets the value filter values for the result definition.
Note: The result definition can only be modified if it is not cached.
from
The value filter if the value type is “<=” or “>=” or the ‘from’ value filter if the value filter type is “Range”.
to
The ‘to’ value filter value which is used if the value filter type is “Range”.
To set the value filter range from 25 to 50 for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetValueFilterType Range
sdefine SetValueFilter 25 50
hwi CloseStack
None.
Related Topics
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
