offset
Default values for the offset functionality of Model Verification.
注: The settings in this block should not be changed.
Settings
action
Type or Run to be selected. Offset=Surfaces will offset if thickness value exists. No-offset=all the surface/solids will be read, no offset applied and converted to HM format by assigning PID, Material and Thickness
Supported values: offset, no-offset. Offset is recommended.
value
Default GUI Value for % thickness value.
Supported values: 50
mode
Default GUI Value.
Supported values: interactive or background
use_result_directory
The resulting .hm files are stored in the report directory rather than the input directory.
Supported values: ON (recommended) or OFF.
matvec-normalcheck
Applicable for material vector based offset logic. If ON, the surface normal is compared with matvec normal direction, and the surface will be reverted to suit matvec line direction
matvec-thick
Check for thickness update.
Supported values: ON or OFF (recommended).
matvec-linetol
Tolerance to search a line from its nearest surfaces.
Supported values: 0-5, 1.0mm is recommended.
matvec-angle
Allowable positive / negative angle value.
Supported values: 0-90 degrees. 15 degrees is recommended.
matvec-comp
Material vector or Matrix Line Component name or assembly name.
Supported values: MV
offset-direction
Material Vector or Matrix Line exist near hole or surface.
Supported values: hole or surface
surface-reverse-normal
If the value is 1, surface normals are reversed, recommended for few specific Catia data.
Supported values: 0 or 1
