HMIN_writeattribute_double_array2d()
Transfers a 2-D double array to HyperMesh.
void HMIN_writeattribute_double_array2d(HM_entitytype entitytype, HM_entityidtype id, int identifier, int behavior, int status, const double *value, int rows, int cols);
HyperMesh hminlib Function
entitytype
The type of the entity to which to attach the attribute.
id
identifier
The attribute identifier (defined in a template with the *defineattribute() command).
behavior
Set to 0, reserved for future use.
status
Set to 0 for off.
Set to 1 for on.
Set to 2 for always on.
value
The values to be assigned to the attribute.
rows
The number of rows in the array.
cols
The number of columns in the array.
None.
