HMIN_writeattribute_entity_array2d()
Transfers a 2-D entity array attribute to HyperMesh.
void HMIN_writeattribute_entity_array2d(HM_entitytype entitytype, HM_entityidtype id, int identifier, int behavior, int status, HM_entitytype attributetype, const HM_entityidtype id_array[], int rows, int cols)
HyperMesh hminlib Function
entitytype
The type of entity to which to attach the attribute.
id
The ID of the entity to which to attach the attribute.
identifier
The attribute identifier (defined in a template with the *defineattribute() command).
behavior
Set to 0, reserved for future use.
status
Set to 0 for off.
Set to 1 for on.
Set to 2 for always on.
attributetype
The type of entity to which the attribute references.
id_array
The entity values to assign to the attributes array.
rows
The number of rows in the array.
cols
The number of columns in the array.
None.
