HMIN_writeattribute_entity_array()
Transfers an entity array attribute to HyperMesh.
void HMIN_writeattribute_entity_array(HM_entitytype entitytype, HM_entityidtype id, int identifier, int behavior, int status, HM_entitytype attributetype, const HM_entityidtype id_array[], int length)
HyperMesh hminlib Function
entitytype
The type of entity to which to attach the attribute.
id
The ID of the entity to which to attach the attribute.
identifier
The attribute identifier (defined in a template with the *defineattribute() command).
behavior
Set to 0, reserved for future use.
status
Set to 0 for off.
Set to 1 for on.
Set to 2 for always on.
attributetype
The type of entity to which the attribute references.
id_array
The entity values to assign to the attribute array.
length
The length of the array.
None.
