HMIN_writeattribute_int_array()
Transfer an integer array attribute to HyperMesh.
void HMIN_writeattribute_int_array(HM_entitytype entitytype, HM_entityidtype id, int identifier, int behavior, int status, const int value[], int length);
HyperMesh hminlib Function
entitytype
The type of the entity to which to attach the attribute.
id
The ID of the entity to which to attach the attribute.
identifier
The attribute identifier (defined in a template with the *defineattribute() command).
behavior
Reserved for future use. Must be set to 0.
status
Set to 0 for off.
Set to 1 for on.
Set to 2 for always on.
value
The values to be assigned to the attribute.
length
The length of the array.
None.
