The CSV comparison tool compares CAD/FE attributes against the CSV file
column.
Supported attributes are Part name, PID, Part Number, Material Name, Thickness and
File name. It has three options, compare, compare-update and create new XML.
In the Comparisonブラウザ, right-click and select
CSV Comparison from the コンテキストメニュー.
Click Compare.
The File Selection window opens.
A CSV file must be selected.
Check will proceed.
Generates reports showing the updated information
in the Excel report, the same as comparison.
