.force file
The .force file is an OptiStruct ASCII format results file.
File Creation
Creation of this file is controlled by the FORCE (ELFORCE) I/O Option.
File Contents
| Result | Description |
| Force | Force results from Linear
Static Analysis for ELAS (CELAS1,
CELAS2, CELAS3,
CELAS4), ROD (CROD), BAR
(CBAR, CBEAM), BUSH
(CBUSH), PLATE (CQUAD,
CTRIA), and GAP (CGAP)
elements. Force results from Normal Modes Analysis for ELAS (CELAS1, CELAS2), ROD (CROD), BAR (CBAR), PLATE (CQUAD4, CQUAD8, CTRIA3, CTRIA6, CSHEAR), SHEAR (CSHEAR), BUSH (CBUSH), GAP (CGAP, CGAPG), CONTACT (CGAPG), WELD (CWELD), and FAST (CFAST) elements. |
File Format
| ITER | Iteration_number | Number_of_subcases/Number_of_Modes |
- Data
- Description
- ITER
- Keyword denoting the beginning of a new iteration.
- Iteration_number
- Iteration number.
- Number_of_subcases
- Number of subcases for which this output is created.
- Number_of_Modes
- Total number of modes of all subcases for which this output is created.
Static Subcase
| Id | Number_of_elements | Frequency | LOAD:Spc_id(Datatype) | subcase_label |
- Data
- Description
- ID
- Output identification number for the subcase. This is not the same as the subcase ID used in the input data.
- Number_of_elements
- Number of elements for which this output is requested.
- Frequency
- 1.0
- Static analysis.
- LOAD
- Keyword declaring applied load information.
- Spc_id
- The SID for SPC's referenced by this subcase.
- (Datatype)
- Keyword indicating the type of subcase involved.
Normal Modes Subcase
| Id | Number_of_elements | FREQ: FRID freq | Subcase_label |
- Data
- Description
- ID
- FREQ
- Keyword identifying the modal frequency.
- FRID
- ID of the modal frequency for which output is printed.
- Freq
- Value of the modal frequency for which the output is printed.
- (Datatype)
Static Subcase .force File Example
| ELAS # | FORCE | |||||||
| ROD# | FORCE-A | FORCE-B | ||||||
| BUSH# | F-X | F-Y | F-Z | M-X | M-Y | M-Z | ||
| BAR# | END | AXIAL | SHEAR-1 | SHEAR-2 | TORQUE | BENDING-1 | BENDING-2 | |
| PLATE# | MEMB-X | MEMB-Y | MEMB-XY | BEND-X | BEND-Y | TWIST-XY | SHEAR-XZ | SHEAR-YZ |
| GAP# | COMP-X | SHEAR-Y | SHEAR-Z |
Element force output is then listed under these headings, depending on the type of elements for which this output was selected. The format of the element output matches the corresponding header, that is for ROD elements you would get FORCE-A and FORCE-B; whereas, for PLATE elements you would get MEMB-X, MEMB-Y, MEMB-XY, BEND-X, BEND-Y, TWIST-XY, SHEAR-XZ, SHEAR-YZ.
| Eid | value1 | value2 | value3 | etc. |
- Data
- Description
- Eid
- Element identification number.
- value#
- Force result corresponding to the column header.
- The I/O Option Previously Supported Results controls the frequency of output for analytical results during an optimization.
