.joint file
The .joint file is an ASCII format results file.
File Creation
This file is created when STRESS and/or STRAIN I/O Options with OPTI option is specified in an input file which contains JOINTG. Refer to JOINTG Bulk Data Entry.
File Contents
This file contains the Displacements, Forces, and Moments, Reaction Forces, Viscous Damping Forces, and Stop/Lock Status in the joint for the final load increment for each JOINTG ID. Viscous Damping Forces are output only if the PROPERTY field on PJOINTG is set to DAMP. If NLOUT entry is defined, then intermediate load increment results are also printed in the .joint file.
File Format
The .joint file has the following format.
For each iteration, the following header is used:
iter Iteration Numlds
Where,
iter
Keyword denoting the beginning of a new iteration
Iteration
Iteration number
NumIds
Number of load increments for which this output is created
Each iteration section is divided up by subcase. Output for each subcase starts with a line in the following format:
Id Number_of_els DISP:Spc_id (or)
FRCE:Spc_id (or)
RFRM:Spc_id (or)
SLST:Spc_id (or)
VFVM:Spc_id
Nonlinear Load Factor: #
Where,
Id
Output identification number for the subcase. This is not the same as the subcase ID used in the input data.
Number_of_els
Number of elements for which this output is printed.
DISP, FRCE, RFRM, SLST, or VFVM
Keywords indicating that corresponding Displacement or Force results are printed.
Spc_id
SID for SPC's referenced by this subcase.
Load Increment at which the results are output.
Displacement information is then provided, for each element, in the following format:
JOINTG # EID Disp-X Disp-Y Disp-Z Rota-X Rota-Y Rota-Z
Where,
JOINTG # EID
Element identification number of the JOINTG element EID.
Disp-X
Displacement in X-direction for the corresponding JOINTG element EID
Disp-Y
Displacement in Y-direction for the corresponding JOINTG element EID
Disp-Z
Displacement in Z-direction for the corresponding JOINTG element EID
Rota-X
Rotation in X-direction for the corresponding JOINTG element EID
Rota-Y
Rotation in Y-direction for the corresponding JOINTG element EID
Rota-Z
Rotation in Z-direction for the corresponding JOINTG element EID
Force information is then provided, for each element, in the following format:
JOINTG # EID F-X F-Y F-Z M-X M-Y M-Z
Where,
JOINTG # EID
F-X
Force in X-direction for the corresponding JOINTG element EID
F-Y
Force in Y-direction for the corresponding JOINTG element EID
F-Z
Force in Z-direction for the corresponding JOINTG element EID
M-X
Moment in X-direction for the corresponding JOINTG element EID
M-Y
Moment in Y-direction for the corresponding JOINTG element EID
M-Z
Moment in Z-direction for the corresponding JOINTG element EID
Reaction Force/Moment information is then provided, for each element, in the following format:
JOINTG # EID RF-X RF-Y RF-Z RM-X RM-Y RM-Z
Where,
JOINTG # EID
RF-X
Reaction Force in X-direction for the corresponding JOINTG element EID
RF-Y
Reaction Force in Y-direction for the corresponding JOINTG element EID
RF-Z
Reaction Force in Z-direction for the corresponding JOINTG element EID
RM-X
Reaction Moment in X-direction for the corresponding JOINTG element EID
RM-Y
Reaction Moment in Y-direction for the corresponding JOINTG element EID
RM-Z
Reaction Moment in Z-direction for the corresponding JOINTG element EID
Stop/Lock Status information is then provided, for each element, in the following format:
JOINTG # EID SLST-1 SLST-2 SLST-3 SLST-4 SLST-5 SLST-6
Where,
JOINTG # EID
SLST-1
Stop/Lock Status in direction 1 for the corresponding JOINTG element EID
SLST-2
Stop/Lock Status in direction 2 for the corresponding JOINTG element EID
SLST-3
Stop/Lock Status in direction 3 for the corresponding JOINTG element EID
SLST-4
Stop/Lock Status in direction 4 for the corresponding JOINTG element EID
SLST-5
Stop/Lock Status in direction 5 for the corresponding JOINTG element EID
SLST-6
Stop/Lock Status in direction 6 for the corresponding JOINTG element EID
Viscous Damping Force information is then provided, for each element, in the following format:
JOINTG # EID VF-X VF-Y VF-Z VM-X VM-Y VM-Z
Where,
JOINTG # EID
VF-X
Viscous Damping Force in X-direction for the corresponding JOINTG element EID
VF-Y
Viscous Damping Force in Y-direction for the corresponding JOINTG element EID
VF-Z
Viscous Damping Force in Z-direction for the corresponding JOINTG element EID
VM-X
Viscous Damping Moment in X-direction for the corresponding JOINTG element EID
VM-Y
Viscous Damping Moment in Y-direction for the corresponding JOINTG element EID
VM-Z
Viscous Damping Moment in Z-direction for the corresponding JOINTG element EID
