Flow Simulator
Flow Simulator
  1. Home
  2. Solver Technical Manual
  3. Elements
  • What's New
  • Get Started
  • Tutorials
  • Quick Start Guide
  • Graphical User Interface
  • Solver Technical Manual
  • Flow Simulator General Guide
Index
Flow Simulator
Flow Simulator
  • What's New
    View new features for Flow Simulator 2022.
  • Get Started
    Flow Simulator is an integrated flow, heat transfer, and combustion design software that enables multidisciplinary engineering simulations to optimize machine design
  • Tutorials
    Discover Flow Simulator functionality with interactive tutorials.
  • Quick Start Guide
    • General Overview
    • Inbuilt Material Properties
    • Chambers
    • Elements
      • Elements Overview
      • Advanced Orifice Element
      • Bearing Elements
      • Bend Elements
      • Brush Seal Element
      • Centrifugal Pump Elements
      • Combination Flow Elements
      • Combustion Element
      • Diffuser Element
      • Effective Area Orifice Elements
      • Elevation Element
      • Fan, Compressors, and Turbine Elements
      • FI CdComp Elements
      • Fixed Flow Elements
      • Incompressible Tube Element
      • Junction Elements
      • Naca Scoop Element
      • Orifice Element
      • Orifice Plates
      • Positive Displacement Pump Element
      • Spline Seal Element
      • Supersonic Tube
      • Transition Elements
      • Tube Elements
      • Turbulator Passage Elements
      • Valve Elements
      • Vermes Seal Element
      • Vortex Elements
      • WSeal Element
    • Components
    • Cavities
    • Thermal Network
    • Controllers
    • User Defined Element (UDE)
    • General Functions and Routines
    • References
Flow Simulator
Flow Simulator
  1. Home
  3. Elements
  • What's New
  • Get Started
  • Tutorials
  • Quick Start Guide
Index
Elements
  1. Elements Overview
  2. Advanced Orifice Element
  3. Bearing Elements
  4. Bend Elements
  5. Brush Seal Element
  6. Centrifugal Pump Elements
  7. Combination Flow Elements
  8. Combustion Element
  9. Diffuser Element
  10. Effective Area Orifice Elements
  11. Elevation Element
  12. Fan, Compressors, and Turbine Elements
  13. FI CdComp Elements
  14. Fixed Flow Elements
  15. Incompressible Tube Element
  16. Junction Elements
  17. Naca Scoop Element
  18. Orifice Element
  19. Orifice Plates
  20. Positive Displacement Pump Element
  21. Spline Seal Element
  22. Supersonic Tube
  23. Transition Elements
  24. Tube Elements
  25. Turbulator Passage Elements
  26. Valve Elements
  27. Vermes Seal Element
  28. Vortex Elements
  29. WSeal Element
