Flow Simulator
Flow Simulator
  1. Home
  2. Solver Technical Manual
  3. Elements
  4. Supersonic Tube
  • What's New
  • Get Started
  • Tutorials
  • Quick Start Guide
  • Graphical User Interface
  • Solver Technical Manual
  • Flow Simulator General Guide
Index
Flow Simulator
Flow Simulator
  • What's New
    View new features for Flow Simulator 2022.
  • Get Started
    Flow Simulator is an integrated flow, heat transfer, and combustion design software that enables multidisciplinary engineering simulations to optimize machine design
  • Tutorials
    Discover Flow Simulator functionality with interactive tutorials.
  • Quick Start Guide
    • General Overview
    • Inbuilt Material Properties
    • Chambers
    • Elements
      • Elements Overview
      • Advanced Orifice Element
      • Bearing Elements
      • Bend Elements
      • Brush Seal Element
      • Centrifugal Pump Elements
      • Combination Flow Elements
      • Combustion Element
      • Diffuser Element
      • Effective Area Orifice Elements
      • Elevation Element
      • Fan, Compressors, and Turbine Elements
      • FI CdComp Elements
      • Fixed Flow Elements
      • Incompressible Tube Element
      • Junction Elements
      • Naca Scoop Element
      • Orifice Element
      • Orifice Plates
      • Positive Displacement Pump Element
      • Spline Seal Element
      • Supersonic Tube
      • Transition Elements
      • Tube Elements
      • Turbulator Passage Elements
      • Valve Elements
      • Vermes Seal Element
      • Vortex Elements
      • WSeal Element
    • Components
    • Cavities
    • Thermal Network
    • Controllers
    • User Defined Element (UDE)
    • General Functions and Routines
    • References
Flow Simulator
Flow Simulator
  1. Home
  3. Elements
  4. Supersonic Tube
  • What's New
  • Get Started
  • Tutorials
  • Quick Start Guide
Index
Supersonic Tube
****Planned updates for next release****
