pltIPlot BarValuesDisplayed
Indicates whether values are displayed above the bars.
pltIPlot_handle BarValuesDisplayed
HyperWorks Tcl Modify
This command indicates whether values are displayed above the bars in a bar chart.
Note: This method is only valid for bar charts. This command returns true when the values are displayed above the bars or false value, if the values are not displayed above the bars.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot BarValuesDisplayed;
Success (true or false) or an error message is returned.
Keywords
HyperWorks
Tcl
Bar Graph
Modify
