pltIPlot PasteVerticalDatum
Pastes the previously copied or cut vertical datum.
pltIPlot_handle PasteHorizontalDatum index
HyperWorks Tcl Modify
This command pastes previously copied or cut vertical datum into the datum list. A datum is a line used to for comparisons.
index
The index (position number) where you want to insert datum. PasteVerticalDatum pastes the user-input index and moves the list down one position if it is at or below that index.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot PasteHorizontalDatum 3;
Keywords
HyperWorks
Tcl
XY plot
Datums
Modify
