pltIPlot SetUniformAspectRatio
Sets the plot to use a uniform aspect ratio.
pltIPlot_handle SetUniformAspectRatio true, false
HyperWorks Tcl Modify
True
The plot uses a uniform aspect ratio.
False
The plot does not use a uniform aspect ratio.
To force the current plot to draw with a uniform aspect ratio (i.e., equal width and height):
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWindowName 1
myWindowName GetClientHandle myPlotName
myPlotName SetUniformAspectRatio true
Returns success or an error code.
