pltIPlot SetBarGapToDefault
Sets the bar gap for the plot to its default.
pltIPlot_handle SetBarGapToDefault
HyperWorks Tcl Modify
This command sets the bar gap for the plot to its default distance.
Note: This method is only valid for bar charts. The bar gap is the distance between each bar in a bar chart (the bar gap will be the same between all bars in a chart).
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot SetBarGapToDefault;
Keywords
HyperWorks
Tcl
Bar Graph
Modify
