pltIPlot PastePhaseDatum
Pastes previously copied or cut phase datum lines.
pltIPlot_handle PastePhaseDatum index
HyperWorks Tcl Modify
This command pastes previously copied or cut phase datum lines into the datum list. A phase datum is a line that goes from the center outward in the polar plot. It is used for comparison.
index
The index (position number) where you want to insert datum line. PastePhaseDatum pastes in the user-input index and moves the list down one position if it is at or below that index (as to make room for the paste).
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot PastePhaseDatum 3;
Keywords
HyperWorks
Tcl
Polar Plots
Datums
Modify
