pltIPlot CutNote
Cuts a note.
pltIPlot_handle CutNote note, append_future
HyperWorks Tcl Modify
This command cuts a note based on the user-input datum index.
note
The note index (position in the note list) that you want to cut.
append_future
true
Indicates the cut is added to a memory.
false
Indicates that the cut is not added to memory. This way, multiple cuts can be made and pasted at the same time, rather than cutting and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CutNote 1 false;
Keywords
HyperWorks
Tcl
Note
Modify
