pltIPlot GetNumberOfEntitiesOnClipboard
Finds the number of objects on the clipboard.
pltIPlot_handle GetNumberOfEntitiesOnClipboard type
HyperWorks Tcl Query
This command finds the total number of objects on the clipboard based on the type that you are looking for.
type
The type of copied or cut item that you are looking for on the clipboard. For example, note. Note is input when you want to find the number of notes on the clipboard.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetNumberOfEntitiesOnClipboard note;
Success (the number of objects on the clipboard) or an error message is returned.
Keywords
HyperWorks
Tcl
Query
