LAW92は、超弾性の挙動のモデル化に使用できるArruda-Boyce材料モデルを記述します。このモデルは、対角線方向に沿って8個のチェーンを擁する立方体の代表的なボリューム要素の材料の統計的な機構に基づいています。
チェーンの分子は、主ストレッチ空間内で立方体の対角線に沿って平均的に配置されています。
材料パラメータ
ひずみエネルギー密度関数は:
(1)
W
μ
i
1
5
c
i
λ
m
2
i
2
I
1
i
3
i
W
I
1
1
D
J
2
1
2
ln
J
U
J
MathType@MTEF@5@5@+=
feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr
4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9
vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbGaey
ypa0ZaaGbaaeaacqaH8oqBdaaeWbqaamaalaaabaGaam4yamaaBaaa
leaacaWGPbaabeaaaOqaaiaacIcacqaH7oaBdaWgaaWcbaGaamyBaa
qabaGccaGGPaWaaWbaaSqabeaacaaIYaGaamyAaiabgkHiTiaaikda
aaaaaaqaaiaadMgacqGH9aqpcaaIXaaabaGaaGynaaqdcqGHris5aO
WaaeWaaeaaceWGjbGbaebadaqhaaWcbaGaaGymaaqaaiaadMgaaaGc
cqGHsislcaaIZaWaaWbaaSqabeaacaWGPbaaaaGccaGLOaGaayzkaa
aaleaacaWGxbWaaeWaaeaaceWGjbGbaebadaWgaaadbaGaaGymaaqa
baaaliaawIcacaGLPaaaaOGaayjo+dGaey4kaSYaaGbaaeaadaWcaa
qaaiaaigdaaeaacaWGebaaamaabmaabaWaaSaaaeaacaWGkbWaaWba
aSqabeaacaaIYaaaaOGaeyOeI0IaaGymaaqaaiaaikdaaaGaey4kaS
IaciiBaiaac6gaciGGOaGaamOsaiaacMcaaiaawIcacaGLPaaaaSqa
aiaadwfadaqadaqaaiaadQeaaiaawIcacaGLPaaaaOGaayjo+daaaa@692A@
材料定数
c
i
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGJbWaaS
baaSqaaiaadMgaaeqaaaaa@3861@
は:
c
1
1
2
c
2
1
20
c
3
11
1050
c
4
19
7000
c
5
519
673750
vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4yamaaBa
aaleaacaaIXaaabeaakiabg2da9maalaaabaGaaGymaaqaaiaaikda
aaGaaiilaiaaysW7caWGJbWaaSbaaSqaaiaaikdaaeqaaOGaeyypa0
ZaaSaaaeaacaaIXaaabaGaaGOmaiaaicdaaaGaaiilaiaaysW7caWG
JbWaaSbaaSqaaiaaiodaaeqaaOGaeyypa0ZaaSaaaeaacaaIXaGaaG
ymaaqaaiaaigdacaaIWaGaaGynaiaaicdaaaGaaiilaiaaysW7caWG
JbWaaSbaaSqaaiaaisdaaeqaaOGaeyypa0ZaaSaaaeaacaaIXaGaaG
yoaaqaaiaaiEdacaaIWaGaaGimaiaaicdaaaGaaGjbVlaacYcacaaM
e8Uaam4yamaaBaaaleaacaaI1aaabeaakiabg2da9maalaaabaGaaG
ynaiaaigdacaaI5aaabaGaaGOnaiaaiEdacaaIZaGaaG4naiaaiwda
caaIWaaaaaaa@625B@
I
1
λ
1
2
λ
2
2
λ
3
2
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaceWGjbGbae
badaWgaaWcbaGaaGymaaqabaGccqGH9aqpcuaH7oaBgaqeamaaDaaa
leaacaaIXaaabaGaaGOmaaaakiabgUcaRiqbeU7aSzaaraWaa0baaS
qaaiaaikdaaeaacaaIYaaaaOGaey4kaSIafq4UdWMbaebadaqhaaWc
baGaaG4maaqaaiaaikdaaaaaaa@4567@
1つ目のひずみ不変量
λ
i
i
t
h
feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAamaaBa
aaleaacaWG0bGaamiAaaqabaaaaa@38F6@
主工学ストレッチ
LAW92を伴う材料は、次の2つの方法で定義することができます:
パラメータ入力せん断弾性係数、体積弾性係数、およびひずみストレッチ(
μ
D
λ
m
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH8oqBca
GGSaGaamiraiaacYcacqaH7oaBdaWgaaWcbaGaamyBaaqabaaaaa@3D10@
明らかな物理的意味を有する上記の3つのパラメータのみ、材料に定義される必要があります。
μ
はゼロひずみにおけるせん断弾性係数。
(2)
D
2
K
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGebGaey
ypa0ZaaSaaaeaacaaIYaaabaGaam4saaaaaaa@39CA@
ここで、
K
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4saaaa@36C6@
ゼロひずみにおける体積係数
λ
m
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH7oaBda
WgaaWcbaGaamyBaaqabaaaaa@3931@
ストレッチの限界を定義
ロッキングストレッチ とも呼ばれ、引張りにおける硬化フェイズ(引張りにおけるロッキングひずみ)の開始を指定。デフォルト = 7.0
図 1. ロッキングストレッチ
λ
m
パラメータ入力では、ポアソン比が次のように計算されます:
(3)
ν
3
K
2
μ
6
K
2
μ
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH9oGBcq
GH9aqpdaWcaaqaaiaaiodacaWGlbGaeyOeI0IaaGOmaiabeY7aTbqa
aiaaiAdacaWGlbGaey4kaSIaaGOmaiabeY7aTbaaaaa@42FD@
関数入力の使用時、ポアソン比
ν
Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH9oGBaa
a@3817@
とItype を定義する必要があります。Itype は、入力としてどのタイプの工学的応力ひずみ試験データを使用するかを定義します。
図 2. Itype = 1: 単軸データ試験
図 3. Itype = 2: 等2軸データ試験
図 4. Itype = 3: 平面データ試験
ポアソン比と材料の非圧縮性
関数入力が定義されると、パラメータ
μ
D
λ
m
は無視され、Radioss は入力関数をフィッティングすることで材料定数を計算します。Radioss によるArruda-Boyceパラメータのフィッティングには、非線形最小2乗アルゴリズムが使用されます。カーブのフィッティングは、ポアソンの値が0.5に近い、すなわち材料が非圧縮性であるという仮定のもとで行われます。その他の超弾性材料モデルと同様、ポアソン比の値が0.5に近いと、体積弾性係数は大きくなり、時間ステップは小さくなります。非圧縮性とリーズナブルな時間ステップの良好なバランスのためには、ポアソン比の値は0.495が推奨されます。
材料フィッティングの情報は、Starter出力ファイル(
*0000.out )で見つかります。
図 5. LAW92関数の例
フィッティングのエラーおよびフィッティングされた材料パラメータは、Starter出力ファイルに出力されます。
図 6.
粘性(速度)効果
粘性効果を含めるには、LAW92と共に/VISC/PRONY を使用する必要があります。
