Aligning Torque Steer
Request Number: 80000100
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | Left Parallel Aligning Torque Steer | deg/100N-m | The left wheel steer due to parallel aligning torques (about global Z)
applied to the left and right wheels or: 1E5*(C(6,6) + C(6,12))*rtod |
F3 | RESULT(3) | Right Parallel Aligning Torque Steer | deg/100N-m | The right wheel steer due to parallel aligning torques (about global Z)
applied to the left and right wheels or: 1E5*(C(12,6) + C(12,12))*rtod |
F4 | RESULT(4) | Average Parallel Aligning Torque Steer | deg/100N-m | The mean of the left and right parallel aligning torque steer. |
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Left Converging Aligning Torque Steer | deg/100N-m | The left wheel steer due to converging aligning torques (about global Z)
applied to the left and right wheels or: 1E5*(C(6,6) - C(6,12))*rtod |
F7 | RESULT(7) | Right Converging Aligning Torque Steer | deg/100N-m | The right wheel steer due to converging aligning torques (about global Z)
applied to the left and right wheels or: 1E5*(C(12,6) - C(12,12))*rtod |
F8 | RESULT(8) | Average Converging Aligning Torque Steer | deg/100N-m | The mean of the left and right converging aligning torque steer. |
