Front View Swing Arm Length and Angle
Request Number: 80000160
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | Left Wheel Front View Swing Arm Length | mm | The distance between the left wheel center and the left wheel center front
view instant center. It is calculated using the following equations:
F3 | RESULT(3) | Right Wheel Front View Swing Arm Length | mm | The distance between the right wheel center and the right wheel center front
F4 | RESULT(4) | Average Front View Swing Arm Length | mm | The mean of the left and right wheel front view swing arm length. |
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Left Wheel Front View Swing Arm Angle | deg | The front view angle between horizontal and the line connecting the left
wheel center and the left wheel center front view instant center. It is calculated
F7 | RESULT(7) | Right Wheel Front View Swing Arm Angle | deg | The front view angle between horizontal and the line connecting the right
wheel center and the right wheel center front view instant center. It is
F8 | RESULT(8) | Average Front View Swing Arm Angle | deg | The mean of the left and right wheel front view swing arm angle. |
