Wheel Vertical Displacement and Vertical Force
Request Number: 80000000
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | Left Wheel Center Vertical Displacement | mm | The global vertical displacement of the left wheel. The sign is positive when the wheel center moves up (jounce) and negative when the wheel center moves down (rebound). |
F3 | RESULT(3) | Right Wheel Center Vertical Displacement | mm | The global vertical displacement of the right wheel. The sign is positive when the wheel center moves up (jounce) and negative when the wheel center moves down (rebound). |
F4 | RESULT(4) | Average Wheel Center Vertical Displacement | mm | The mean of the left and right wheel center vertical displacement. |
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Left Wheel Center Vertical Force | N | The global vertical force between the left wheel part and the jack (vertical constraint) mechanism. |
F7 | RESULT(7) | Right Wheel Center Vertical Force | N | The global vertical force between the right wheel part and the jack (vertical constraint) mechanism. |
F8 | RESULT(8) | Average Wheel Center Vertical Force | N | The mean of the left and right wheel center vertical force. |
