Roll Steer, Caster, and Camber
Request Number: 80000190
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | Left Wheel Roll Steer | % (deg/100 deg) | The left wheel steer angle change due to out-of-phase vertical deflections of
the left and right tire patch points expressed in degrees of axle roll
or: track = abs((right wheel center y) - (left wheel center y)) deltaz = C(3,3)-C(3,9)-C(9,3)+C(9,9)+2/(tire stiffness) roll steer = (C(6,3) - C(6,9))*track/deltaz*100 |
F3 | RESULT(3) | Left Roll Caster | % (deg/100 deg) | The left caster angle change due to out-of-phase vertical deflections of the
F4 | RESULT(4) | Left Wheel Roll Camber | % (deg/100 deg) | The left wheel camber angle change due to out-of-phase vertical deflections
of the left and right tire patch points expressed in degrees of axle roll
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Right Wheel Roll Steer | % (deg/100 deg) | The right wheel steer angle change due to out-of-phase vertical deflections
or: track = abs((right wheel center y) - (left wheel center y)) deltaz = C(3,3)-C(3,9)-C(9,3)+C(9,9)+2/(tire stiffness) roll steer = (C(12,3) - C(12,9))*track/deltaz*100 |
F7 | RESULT(7) | Right Roll Caster | % (deg/100 deg) | The right caster angle change due to out-of-phase vertical deflections of the
F8 | RESULT(8) | Right Wheel Roll Camber | % (deg/100 deg) | The right wheel camber angle change due to out-of-phase vertical deflections
