Roll Inclination
Request Number: 80000200
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | Left Wheel Roll Inclination | % (deg/100 deg) | The left wheel camber angle change with respect to the true ground line (line
connecting tire patches) due to out-of-phase vertical deflections of the left and
right tire patch points expressed in degrees of axle roll
or: track = abs((right wheel center y) - (left wheel center y)) deltaz = C(3,3)-C(3,9)-C(9,3)+C(9,9)+2/(tire stiffness)
F3 | RESULT(3) | Right Wheel Roll Inclination | % (deg/100 deg) | The right wheel camber angle change with respect to the true ground line
(line connecting tire patches) due to out-of-phase vertical deflections of the
left and right tire patch points expressed in degrees of axle roll
F4 | RESULT(4) | Average Roll Inclination | % (deg/100 deg) | The mean of the left and right wheel roll inclination. |
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Not Used | Not Used | Not Used |
F7 | RESULT(7) | Not Used | Not Used | Not Used |
F8 | RESULT(8) | Not Used | Not Used | Not Used |
