F1 |
RESULT(1) |
Not Used |
Not Used |
Not Used |
F2 |
RESULT(2) |
Left Front Anti-Lift or Left Rear Anti-Squat |
The resistance to lifting in a front suspension or resistance to squatting in
a rear suspension due to suspension geometry during acceleration. In a suspension
with 100% anti-lift/squat the moment about the side view instant center due to
weight transfer is exactly offset by the moment about the side view instant center
due to the acceleration force. See the following equations:
- Front Suspensions Live Axles
- acx = -(front drive ratio)/2
- dtwt = slr*abs(2*acx)/(diff
ratio)/track
- aczleft = -(cg height)/2/(wheel base) -
dtwt
- aczright= -(cg height)/2/(wheel base) +
dtwt
- Orientation A:
- dzfleft =
acx*(C(3,1)-slr*C(3,5))+acx*(C(3,7)-slr*C(3,11))
- dzfright =
acx*(C(9,1)-slr*C(9,5))+acx*(C(9,7)-slr*C(9,11))
- Orientation B:
- dzfleft =
acx*(-C(3,1)+slr*C(3,5))+acx*(-C(3,7)+slr*C(3,11))
- dzfright =
acx*(-C(9,1)+slr*C(9,5))+acx*(-C(9,7)+slr*C(9,11))
- dzwleft = aczleft*C(3,3) +
aczright*C(3,9)
- dzwright = aczleft*C(9,3) +
aczright*C(9,9)
- left anti-lift =
-100*dzfleft/dzwleft
- right anti-lift =
- Front Suspensions Fixed Differentials
base)
base)
- Orientation A:
- dzfleft = acx*C(3,1)+acx*C(3,7)
- dzfright = acx*C(9,1)+acx*C(9,7)
- Orientation B:
- dzfleft = -acx*C(3,1)-acx*C(3,7)
- dzfright = -acx*C(9,1)-acx*C(9,7)
aczright*C(3,9)
aczright*C(9,9)
- left anti-lift =
- right anti-lift =
- Rear Suspensions Live Axles
- acx = -(1 - front drive ratio)/2
ratio)/track
- aczleft = (cg height)/2/(wheel base) -
dtwt
- aczright= (cg height)/2/(wheel base) +
dtwt
- Orientation A:
- dzfleft =
- dzfright =
- Orientation B:
- dzfleft =
- dzfright =
aczright*C(3,9)
aczright*C(9,9)
- left anti-lift =
- right anti-lift =
- Rear Suspensions Fixed Differentials
base)
- aczright = (cg height)/2/(wheel
base)
- Orientation A:
- Orientation B:
aczright*C(3,9)
aczright*C(9,9)
- left anti-lift =
- right anti-lift =
F3 |
RESULT(3) |
Right Front Anti-Lift or Right Rear Anti-Squat |
See F2/RESULT(2) (above) for explanation and equations. |
F3 |
RESULT(3) |
Average Front Anti-Lift or Rear Anti-Squat |
The mean of the left and right front anti-lift or left and right rear
anti-squat. |
F4 |
RESULT(4) |
Left Front Lift or
Left Rear Squat
mm/g |
The front suspension lift or rear suspension squat during acceleration or:
- Front Suspensions
- left lift = -(dzfleft+dzwleft+aczleft/(tire
stiffness))*weight
- Rear Suspensions
- left squat = (dzfleft+dzwleft+aczleft/(tire
stiffness))*weight
F5 |
RESULT(5) |
Right Front Lift or Right Rear Squat
mm/g |
- Front Suspensions
- right lift = -(dzfright+dzwright+aczright/(tire
stiffness))*weight
- Rear Suspensions
- right squat = (dzfright+dzwright+aczright/(tire
stiffness))*weight
F6 |
RESULT(6) |
Average Front Lift or Rear Squat |
mm/g |
The mean of the left and right front lift or left and right rear
squat. |
