Lateral Force Steer
Request Number: 80000080
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | Left Parallel Lateral Force Steer | deg/kN | The left wheel steer due to parallel lateral forces on the left and right
tire patches or:
F3 | RESULT(3) | Right Parallel Lateral Force Steer | deg/kN | The right wheel steer due to parallel lateral forces on the left and right
tire patches or:
F4 | RESULT(4) | Average Parallel Lateral Force Steer | deg/kN | The mean of the left and right parallel lateral force steer. |
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Left Converging Lateral Force Steer | deg/kN | The left wheel steer due to converging lateral forces on the left and right
tire patches or:
F7 | RESULT(7) | Right Converging Lateral Force Steer | deg/kN | The right wheel center steer due to converging lateral forces on the left and
right tire patches or:
F8 | RESULT(8) | Average converging Lateral Force Steer | deg/kN | The mean of the left and right converging lateral force steer. |
