Longitudinal Caster Compliance
Request Number: 80000130
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | 1 (X): Left WC Longitudinal Caster Compliance | deg/kN | The left wheel caster change due to parallel longitudinal forces applied to
the left and right wheel centers or: (C(5,1) + C(5,7))*1000*rtod |
F3 | RESULT(3) | 2 (Y): Right WC Longitudinal Caster Compliance | deg/kN | The right wheel caster change due to parallel longitudinal forces applied to
the left and right wheel centers or: (C(11,1) + C(11,7))*1000*rtod |
F4 | RESULT(4) | 3 (Z): Average WC Longitudinal Caster Compliance | deg/kN | The mean of the left and right wheel center longitudinal caster compliance. |
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | 4 (RX): Left TP Longitudinal Caster Compliance | deg/kN | The left wheel caster change due to parallel longitudinal forces applied to
the left and right tire patches or: (C(5,1) + C(5,7) - slr*(C(5,5) + C(5,11)))*1000*rtod |
F7 | RESULT(7) | 5 (RY): Right TP Longitudinal Caster Compliance | deg/kN | The right wheel caster change due to parallel longitudinal forces applied to
the left and right tire patches or: (C(11,1)+ C(11,7)- slr*(C(11,5)+C(11,11)))*1000*rtod |
F8 | RESULT(8) | 6 (RZ): Average TP Longitudinal Caster Compliance | deg/kN | The mean of the left and right tire patch longitudinal caster compliance. |
