Side View Swing Arm Length and Angle
Request Number: 80000140
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | Left Wheel Side View Swing Arm Length | mm | The distance between the left wheel center and the left wheel center side
view instant center. It is calculated using the following equations:
F3 | RESULT(3) | Right Wheel Side View Swing Arm Length | mm | The distance between the right wheel center and the right wheel center side
F4 | RESULT(4) | Average Side View Swing Arm Length | mm | The mean of the left and right wheel side view swing arm length. |
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Left Wheel Side View Swing Arm Angle | deg | The side view angle between horizontal and the line connecting the left wheel
center and the left wheel center side view instant center. It is calculated using
F7 | RESULT(7) | Right Wheel Side View Swing Arm Angle | deg | The side view angle between horizontal and the line connecting the right
wheel center and the right wheel center side view instant center. It is calculated
F8 | RESULT(8) | Average Side View Swing Arm Angle | deg | The mean of the left and right wheel side view swing arm angle. |
