Brake Steer
Request Number: 80000260
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | Left Braking Force Steer | deg/g | The left wheel change in steer angle induced by vehicle braking. See brake
dive/lift above for calculation of intermediate terms.
F3 | RESULT(3) | Right Braking Force Steer | deg/g | The right wheel change in steer angle induced by vehicle braking. See brake
F4 | RESULT(4) | Average Braking Force Steer | deg/g | The mean of the left and right braking force steer. |
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Left Braking Force Windup | deg/g | The left wheel change in caster angle induced by vehicle braking. See brake
F7 | RESULT(7) | Right Braking Force Windup | deg/g | The right wheel change in caster angle induced by vehicle braking. See brake
F8 | RESULT(8) | Average Braking Force Windup | deg/g | The mean of the left and right braking force windup. |
