Ideal Steer Angle
Request Number: 80000280
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | 1 (X): Ideal Steer Angle | deg | The outside wheel steer angle required to produce a turn radius equal to the
turn radius produced by the inside wheel steer angle. It is calculated with the
following equations:
F3 | RESULT(3) | Not Used | Not Used | Not Used |
F4 | RESULT(4) | Not Used | Not Used | Not Used |
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Not Used | Not Used | Not Used |
F7 | RESULT(7) | Not Used | Not Used | Not Used |
F8 | RESULT(8) | Not Used | Not Used | Not Used |
