Wheel Center Translational Stiffnesses
Request Number: 80000050
.plt File | .mr, .abf File | Component | Unit | Comment |
F1 | RESULT(1) | Not Used | Not Used | Not Used |
F2 | RESULT(2) | Left Wheel Center X Stiffness | N/mm | The left wheel center longitudinal stiffness
or: 1/C(1,1) |
F3 | RESULT(3) | Left Wheel Center Y Stiffness | N/mm | The left wheel center lateral stiffness
or: 1/C(2,2) |
F4 | RESULT(4) | Left Wheel Center Z Stiffness | N/mm | The left wheel center vertical stiffness
or: 1/C(3,3) |
F5 | RESULT(5) | Not Used | Not Used | Not Used |
F6 | RESULT(6) | Right Wheel Center X Stiffness | N/mm | The right wheel center longitudinal stiffness
or: 1/C(7,7) |
F7 | RESULT(7) | Right Wheel Center Y Stiffness | N/mm | The right wheel center lateral stiffness
or: 1/C(8,8) |
F8 | RESULT(8) | Right Wheel Center Z Stiffness | N/mm | The right wheel center vertical stiffness
or: 1/C(9,9) |
