Engineering Solutions
2022
  1. Home
  2. Panels
  3. Safety Module
    Use the Safety module to access the panels most frequently used in safety analysis.
  • What's New
  • Get Started
  • Tutorials
  • NVH
  • Squeak and Rattle Director
  • Crash
  • CFD
  • Aerospace
  • CAD Interfaces
  • Browsers
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Model Build and Assembly
  • Model Verification
  • Model Setup
  • Morphing
  • Optimization
  • Conversion Between Solver Formats
  • XY Plotting
  • Post-Processing Analysis
Index
2022
  • What's New
    View new features for Engineering Solutions 2022.
  • Get Started
    Engineering Solutions is a modeling and visualization environment for NVH, Squeak and Rattle Director, Crash, CFD, and Aerospace using best-in-class solver technology.
  • Tutorials
    Discover Engineering Solutions functionality with interactive tutorials.
  • NVH
    Noise, Vibration and Harshness (NVH) is an important vehicle attribute that directly affects the customer experience.
    Use Squeak and Rattle Director tool to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
  • Crash
    The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
  • CFD
    HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing tasks efficiently.
  • Aerospace
    Solver interfaces supported in Engineering Solutions.
  • CAD Interfaces
  • Browsers
    Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
  • Panels
    • 64 more
    • Accels Panel
      Use the Accels (accelerations) panel to create and update concentrated accelerations by applying a load, representing accelerations, nodes, components, sets, surfaces, points, or lines.
    • Acoustic Cavity Mesh Panel
      Use the Acoustic Cavity Mesh panel to create a fluid volume mesh for the open-air volumes of an enclosed compartment, such as the passenger compartment of a vehicle. Structural components such as seats are modeled as separate acoustic volumes. Once generated, this mesh can be used in noise/vibration testing.
    • Admas Panel
      Use the Admas panel to create and update masses applied to nodes. The Adams panel supports the /ADMAS Radioss and *ELEMENT_MASS LS-DYNA element.
    • ALE Setup Panel
      Use the ALE Setup panel to create and modify input data pertaining to the Arbitrary-Lagrangian-Eulerian.
    • Animation Secondary Panel
      Use the Animation Secondary panel to control the display of your model during animation sequences.
    • Apply Result Panel
      Use the Apply Result panel to apply the result's analysis data to selected entities of your model, or create loads from the analysis data.
    • Assemblies Panel
      Use the Assemblies panel to create and modify assemblies, which are collections of component and multibody collectors or other assemblies. This method of grouping component and multibody collectors is useful because once an assembly is created, it is possible to display components or multibodies by assembly, or to select entities by assembly rather than by component.
    • Autocleanup Panel
      Use the Autocleanup panel to perform automatic geometry cleanup and prepare your model for meshing based on the parameters set in the BatchMesher criteria file.
    • Automesh Panel
      Use the Automesh panel to generate a mesh of plate elements using surface geometry or existing shell elements to define the mesh area.
    • Automeshing Secondary Panel
      Use the Automeshing Secondary panel to create meshes interactively on surfaces, or create meshes without a surface present.
    • Axis Labels Panel
      Use the Axis Labels panel to edit the axis label information of the current plot or selected attributes in a group of plots.
    • Axis Scaling Panel
      Use the Axis Scaling panel to modify plot axes.
    • Bars Panel
      Use the Bars panel to create, review, or update bar2 or bar3 elements.
    • Beamsection Collectors Panel
      Use the Beamsection Collectors panel to create and update beamsection collectors.
    • Blocks Panel
      Use the Blocks panel to create and modify a block entity, which are commonly used in most crash solvers.
    • Bodies Panel
      Use the Bodies panel to create, review, and update group entities.
    • Border Panel
      Use the Border panel to edit the appearance of the border that designates the window around an xy plot.
    • By Width
      Use the By Width option in the Extended Entity Selection menu to select surfaces based on their width.
    • By Window
      Use the By Window option in the Extended Entity Selection menu to create a window that can be used to select entities on your model.
    • Card Editor Panel
      Use the Card Editor panel to select entities whose card image you want to view or edit.
    • Card Image Panel
      Use the Card Image panel to edit solver specific data on a set of entities.
    • CFD Tetramesh Panel
      Use the CFD Tetramesh panel to generate hybrid grids, containing hexa/penta/tetra elements in the boundary layer and tetra elements in the core or fare field.
    • Check Elems Panel
      Use the Check Elems pane to verify the basic quality of your elements, as well as the geometric qualities of those elements.
    • Color Panel
      Use the Color panel to change the color attributes of a collector.
    • Component Collectors Panel
      Use the Component collectors panel to create and update components.
    • Composite Shuffle Panel
      Use the Composite Shuffle panel to define manufacturing constraints for composite shuffling optimization.
    • Composite Size Panel
      Use the Composite Size panel to define manufacturing constraints for composite sizing optimization.
    • Composites Panel
      Use the Composites panel to assign and review the element material orientation of a mesh of shell and continuum shell elements, or to review the fiber direction (ply angle) of individual composite layers.
    • Cones Panel
      Use the Cones panel to create an analytic, conical or cylindrical surface and/or mesh.
    • Config Edit Panel
      Use the Config Edit panel to make changes to the configuration of existing elements.
    • Connectors Module
      The Connectors module contains several connector-specific panels that can be used to create and manage connectors.
    • Constr Screen Panel
      Use the Constr Screen panel to define the data for constraint screening.
    • Constraints Panel
      Use the Constraints panel to place constraints or enforced displacements on a model. This is accomplished by assigning a degree of freedom (DOF) constraint to the node.
    • Contactsurfs Panel
      Use the Contactsurfs panel to create and modify contactsurf entities.
    • Contour Loads Tool
      Use the Contour Loads utility to create contour plots of applied loads and boundary conditions contained within load collectors.
    • Contour Panel
      Use the Contour panel to create contour and assigned plots of your model, and view your analysis results, in either a contour or assigned plot mode.
    • Control Cards Panel
      Use the Control Cards panel to set job-level, solver specific data.
    • Control Vol Panel
      Use the Control Vol panel to define control volume objects within a model.
    • Convert Panel
      Use the Convert panel to exchange data between different solver formats.
    • Count Panel
      Use the Count panel to obtain a count of all the entities in your database.
    • Curve Attribs Panel
      Use the Curve Attributes panel to create and edit curves displayed on an xy plot.
    • Dconstraints Panel
      Use the Dconstraints panel to create constraints for an optimization problem.
    • Defeature Panel
      Use the Defeature panel to find and delete pinholes, fillets on surfaces and surface edges, and duplicate surfaces.
    • Deformed Panel
      Use the Deformed (deformed shape) panel to plot displacement analysis results.
    • Delete Panel
      Use the Delete panel to delete data from a model database, preview and delete empty collectors, and preview and delete unused property collectors, material collectors, or curves. You can also delete an entire model database, if you wish to start with a clean database.
    • Dependency Panel
      Use the Dependency panel to find nodes that have their degrees of freedom removed by a constraint or MPC (multiple point constraint) more than once. By identifying and correcting such dependencies prior to solving, solution errors can be avoided.
    • Dequations Panel
      Use the Dequations panel to create user-defined functions for responses and design properties.
    • Desvar Link Panel
      Use the Desvar Link panel to link a design variable to other design variables.
    • Detach Panel
      Use the Detach panel to detach elements from the surrounding structure. You can detach elements from a portion of your model so that it can be translated or moved, or you can offset the new nodes by a specified value. You can also use this panel to detach and remove elements from your model.
    • Dimensioning Panel
      Use the Dimensioning panel to create and manipulate dimension features.
    • Discrete DVS Panel
      Use the Discrete dvs panel to define a discrete design variable value table for use in size or shape optimization, which maybe be referenced in the ddval = field on the Size, Gauge or Shape panels..
    • Distance Panel
      Use the Distance panel to determine the distance between two nodes/points or the angle between three nodes/points, or to change distances or angles.
    • Drag Panel
      Use the Drag panel to create a surface and/or mesh by dragging a series of nodes or lines, or to create elements by dragging selected elements. The selected entities are dragged along the specified vector creating a mesh, surface, or elements along that vector.
    • Dummy Panel
      Use the Dummy Positioning / Joint dof panel to rotate the dummy assemblies or specify the position of the H-Point of a dummy assembly. The dummy database must be organized as a tree structure.
    • Edge Edit Panel
      Use the Edge Edit panel to alter the connectivity status (topology) of adjacent surface edges, and stitch or split surfaces, replace fillets with corners, and suppress or eliminate redundant edges.
    • Edges Panel
      Use the Edges panel to find the free edges in a group of shell elements, find "T" connections in a group of shell elements (any edges connected to three or more elements), display duplicate nodes, and equivalence duplicate nodes.
    • Edit Curves Panel
      Use the Edit Curves panel to create new curves or edit existing ones.
    • Edit Element Panel
      Use the Edit Element panel to hand build, combine, split, or modify elements.
    • Elem Offset Panel
      Use the Elem Offset panel to create and modify elements by offsetting from a mesh of plate or shell elements.
    • Elem Types Panel
      Use the Elem Types panel to select the type of element to create, and also allows you to change existing element types.
    • Element Cleanup Panel
      Use the Element Cleanup panel to perform automatic cleanup of 2D elements based on the element quality criteria from the Quality Index panel or a separate criteria file.
    • Ellipsoids Panel
      Use the Ellipsoids panel to create and modify a single or multiple ellipsoids and cylinders.
    • Entity Sets Panel
      Use the Entity Sets panel to create, update, and review named sets of entities.
    • Equations Panel
      Use the Equations panel to create, review, and update equations.
    • Faces Panel
      Use the Faces panel to find the free faces in a group of elements, and operates in the same manner as edges, but in 3D. It also allows you to find and delete duplicate nodes.
    • Fatigue Configuration File
      The fatigue configuration file is a user-defined external ASCII-file through which the data groups from results of static/modal/transient analysis of different solvers can be read.
    • Fatigue Panel
      Use the Fatigue panel to write stress, strain, force, and moment results from finite element analysis to an external file that can then be used to set up fatigue analysis.
    • FE Joints Panel
      Use the FE joints panel to create, review, or update joint elements. A joint element is a definition of a connection between two rigid bodies. Joint elements store a property and orientation information.
    • Features Panel
      Use the Features panel to identify geometric features of a finite element model based on the relative angle between adjacent elements.
    • Find Panel
      Use the Find panel to locate entities in a database.
    • Finite Difference Panels
      Use the Finite Difference panel to access the finite difference panels.
    • Flux Panel
      Use the Flux panel to apply concentrated fluxes to your model. This is accomplished by applying a load, representing fluxes, to element nodes. Fluxes are load config 6 and are displayed as a thick arrow labeled with the word "flux."
    • Forces Panel
      Use the Forces panel to create concentrated forces. This is accomplished by applying a load, representing forces, to a node, point, set, or component.
    • Free Shape Panel
      Use the Free Shape panel to define design domains for free shape optimization.
    • Free Size Panel
      Use the Free Size panel to define design domains for free size optimization.
    • Gaps Panel - HyperMesh
      Use the Gaps panel to create gap elements.
    • Gaps Panel - OptiStruct
      Use the Gaps panel to create gap elements. When using the OptiStruct solver interface, it allows the creation of multiple node-element gap elements.
    • Gauge Panel
      Use the Gauge panel to create design variables (DESVAR) and property relation (DVPREL1) cards for shell and composite laminate components (PSHELL, PCOMP, and PCOMPG) selected for size optimization.
    • Global Panel
      Use the Global panel to control global parameters that are accessed by several different panels. These parameters remain constant until changed. It also controls which components or collectors are active. Any entities you create are stored in the active collectors. Finally, you can use this panel to specify which template file you want to use. (Template files must first be created.)
    • Grid Attribs Panel
      Use the Grid Attributes panel to edit the grid line information contained in a plot.
    • Grid Labels Panel
      Use the Grid Labels panel to edit the grid labels on the x and y axes of a plot. It allows you to change the font and color of the grid tic marks.
    • Hidden Line Panel
      Use the Hidden Line panel to create hidden line plots of the displayed structure.
    • HyperBeam Panel
      Use the HyperBeam panel to create beam cross-section entities that you can use to simplify complex portions of your model into simple bar elements.
    • HyperMorph Module
      Use the HyperMorph module to alter models in useful, logical, and intuitive ways while keeping mesh distortion to a minimum.
    • Integrate Panel
      Use the Integrate panel to obtain the area under a curve. The area under the curve that has been integrated is shaded and the total area, based on the calculation, is given.
    • Interfaces Panel
      Use the Interfaces panel to create and modify interfaces. Interfaces are mainly used to define contact interactions between various parts of the model.
    • Joints Panel
      Use the Joints panel to create, review and update joint elements for use in an OptiStruct Multi-Body Dynamics simulation.
    • Legend Edit Panel
      Legends display the range of values for the plot. Use the Legend Edit panel to change the number of colors in the legend or the colors of the legend. You can also reverse the colors used in the legend.
    • Legend Panel
      Use the Legend (xy legend) panel to edit the legend associated with an xy plot, for example you can change the font size or the location of the legend.
    • Length Panel
      Use the Length panel to determine the length of a selected group of lines, and determine the length of the black line.
    • Line Drag Panel
      Use the Line Drag panel to create a two- or three-dimensional surface and/or mesh or elements by dragging nodes, lines, or elements along another line.
    • Line Edit Panel
      Use the Line Edit panel to split, join, or extend lines.
    • Line Mesh Panel
      Use the Line Mesh panel to create a chain of one-dimensional elements such as beams along a line.
    • Linear 1D Panel
      Use the Linear 1D panel to create one-dimensional elements.
    • Linear Solid Panel
      Use the Linear Solid panel to create solid elements between two groups of plate elements.
    • Lines Panel
      Use the Lines panel to create lines using a wide variety of methods.
    • Load Collectors Panel
      Use the Load Collectors panel to create and organize load collectors in your model.
    • Load on Geom Panel
      Use the Load on Geom panel to map loads or boundary conditions from geometrical entities (loads on geometry) to the associated FE mesh entities (loads on mesh).
    • Load Steps Panel
      Use the Load Steps panel to create and update collections of load collectors, groups, and output blocks.
    • Load Types Panel
      Use the Load Types panel to update load types and equations.
    • Loads Summary Tool
      Use the Loads Summary tool to create a summary of the loads (node-based forces or moments, and element-based pressures) applied to a model
    • Loadsteps Panel
      Use the Loadsteps panel to create Nastran and OptiStruct loadstep entities, which directly correspond to Nastran and OptiStruct loadstep definitions..
    • Markers Panel
      Use the Markers panel to create, review and update sensor entities.
    • Mask Panel
      Use the Mask panel to mask entities from the display list.
    • Mass Calc Panel
      Use the Mass Calc panel to obtain the mass, area, and/or volume of a selected group of elements, solids, or surfaces.
    • Masses Panel
      Use the Masses panel to create mass elements.
    • Material Collectors Panel
      Use the Material Collectors panel to create, review and edit collectors and card card images or dictionaries.
    • MBS Joints Panel
      Use the MBS joints panel to define kinematic joints between two local coordinate systems to connect two multibody collectors. The Engineering Solutions entity created is an mbjoint.
    • MBS Planes Panel
      Use the MBS planes panel to create rectangular, planar surfaces for use in multi-body analyses. The created entity is an mbplane.
    • Mesh Edit Panel
      Use the Mesh Edit panel to extend a mesh to meet another mesh and form a good connection between them, or to imprint overlapping meshes so that they match one another.
    • Midmesh Panel
      Use the Midmesh Panel to automatically generate a mesh at the midplane location, directly from the input geometry (components, elements, solids or surfaces), without first creating a midsurface.
    • Midsurface Panel
      Use the Midsurface panel to extract the midsurface representation of a solid part or to generate a finite element shell representation of a solid geometry.
    • Moments Panel
      Use the Moments panel to create concentrated moments by applying a load, representing moments, to a node.
    • Multibody Collectors Panel
      Use the Multibody Collectors panel to generate new multibody collectors.
    • Node Edit Panel
      Use the Node Edit panel to associate nodes to a point, line, or surface/solid face; move nodes along a surface; place a node at a point on a surface; remap a list of nodes to a line; or project nodes to an imaginary line passing through two nodes.
    • Nodes Panel
      Use the Nodes panel to create nodes using a wide variety of methods.
    • Normals Panel
      Use the Normals panel to display and reverse the normals of elements or surfaces. The orientation of element normals can also be adjusted. The normal of an element is determined by following the order of nodes of the element using the right-hand rule.
    • NSM Panel
      Use the NSM panel to add non-structural mass entities to a model, or modify existing ones.
    • Numbers Panel
      Use the Numbers panel to display the IDs of an entity.
    • Obj Reference Panel
      Use the OBJ Reference panel to define a response and its reference values for a minmax (maxmin) optimization problem.
    • Objective Panel
      Use the Objective panel to define the objective function for an optimization problem.
    • On Plane Panel
      Use the On Plane panel to select entities that are on or touch a plane.
    • Opti Control Panel
      Use the Opti Control panel to define control parameters for an optimization.
    • Optimization Panel
      Use the Optimization panel to access the most frequently used topology, topography, size, and shape optimizations panels.
    • Options Panel
      Use the Options panel to modify default settings in Engineering Solutions.
    • OptiStruct Panel
      Use the OptiStruct panel to execute an OptiStruct run on your desktop.
    • Order Change Panel
      Use the Order Change panel to change element order.
    • Organize Panel
      Use the Organize panel to (re)organize your database by copying or moving data (entities) among collectors, includes, or parts.
    • OSSmooth Panel
      Use the Ossmooth panel to extract and import the final design geometry from OptiStruct's topology, topography and shape optimization results into Engineering Solutions.
    • Output Blocks Panel
      Use the Output Blocks panel to create and update blocks of entities used for output requests.
    • Penetration Panel
      Use the Penetration panel to check for penetrations and/or intersections of elements. After running the check, you can use additional tools to check the penetration depth and move nodes in order to fix the problem areas; both penetrations and intersections can be fixed.
    • Permute Panel
      Use the Permute panel to switch coordinates of model entities in the global coordinate system.
    • Perturbations Panel
      Use the Perturbations panel to setup shape optimization.
    • Planes Panel
      Use the Planes panel to create a square, planar surface and/or mesh in a user-specified plane, or a surface and/or mesh bounded by planar lines.
    • Plot Titles Panel
      Use the Plot Titles panel to edit the title information contained in a plot.
    • Plots Panel
      Use the Plots panel to create and manage plot collectors.
    • Point Edit Panel
      Use the Point Edit panel to perform many point-specific geometry cleanup tasks.
    • Points Panel
      Use the Points panel to create free points using a wide variety of methods.
    • Position Panel
      Use the Position panel to specify a new position for model entities.
    • Preserve Node Panel
      Use the Preserve Node panel to review free, temporary, and preserved nodes, convert free and temporary nodes into preserved nodes, convert free and temporary nodes into preserved nodes, and remove preserved nodes.
    • Pressures Panel
      Use the Pressures panel to create pressure loads on elements by applying a load, representing pressures, to a 1D or 2D element, or to the face of a solid element.
    • Project Panel
      Use the Project panel to project data entities to a plane, vector, surface, or line.
    • Property Collectors Panel
      Use the Property Collectors panel to create property collectors, which are used to assign physical properties to entities.
    • Quality Index Panel
      Use the Quality Index panel to calculate a single value to represent the quality of the displayed shell (2D) model.
    • Quality Index Cleanup Tools Secondary Panel
      Use the Quality Index Cleanup Tools secondary panel to access tools that assist you in manually relocating nodes and optimizing element topology.
    • Query Curves Panel
      Use the Query Curves panel to determine the x and y values of points in a curve on a plot.
    • Quick Edit Panel
      Use the Quick Edit panel to split surfaces and washers, change the category (shared, free, and so on) of edges, create or delete surfaces and points, project points, and trim fillets.
    • Radioss Panel
      Use the Radioss panel to execute a Radioss run on your desktop from HyperMesh.
    • RBE3 Panel
      Use the RBE3 panel to create, review, and update RBE3 elements.
    • Read Curves Panel
      Use the Read Curves panel to read in an xy data set from an ASCII file. As a result, an xy curve is created that represents that data graphically.
    • Rebuild Mesh Panel
      Use the Rebuild Mesh panel to streamline the process of remeshing existing meshes to generate a new mesh with good quality and flow.
    • Reflect Panel
      Use the Reflect panel to reflect portions of a model about a plane, changing the selected portion into a mirror image of itself.
    • Rename Panel
      Use the Rename panel to change the name of a specific collector or to rename types of collectors to their respective ID with an optional prefix.
    • Renumber Panel
      Use the Renumber panel to renumber entities. You may also enter a value by which to offset the IDs of entities.
    • Reorder Panel
      Use the Reorder panel to change the order of named entities in database.
    • Replace Panel
      Use the Replace panel to relocate one node to the position of another or manually equivalence two nodes.
    • Responses Panel
      Use the Responses panel to create responses for an optimization.
    • Results Curves Panel
      Use the Results Curves panel to create curves by extracting data from an Engineering Solutions binary results file.
    • Ribs Panel
      Use the Ribs panel to create and modify simple ribs between two surfaces.
    • Rigid Walls Panel
      Use the Rigid Walls panel to create and update rigid walls.
    • Rigids Panel
      Use the Rigids panel to create rigid or rigid link elements.
    • Rods Panel
      Use the Rods panel to create rod elements.
    • Rotate Panel
      Use the Rotate panel to rotate entities around an axis in space.
    • Ruled Panel
      Use the Ruled panel to create surfaces and/or meshes of plate elements from nodes, lines, and/or line segments, in any combination.
    • Safety Module
    • Scale Panel
      Use the Scale panel to increase or decrease an entity's dimensions.
    • Sensors Panel
      Use the Sensors panel to create and edit modify sensors.
    • Shape Panel
      Use the Shape panel to create shape design variables and associate them to a shape for shape optimization.
    • Shrink Wrap Panel
      Use the Shrink Wrap panel to generate an enclosed volume or solid mesh, and is typically used to approximate and simplify an existing model.
    • Simple Math Panel
      Use the Simple Math panel to access tool for applying mathematical operations to curves.
    • Size Panel
      Use the Size panel to define design variables and properties for size optimization.
    • Skin Panel
      Use the Skin panel to create a skin surface and/or mesh from a set of lines.
    • Smooth Panel
      Use the Smooth panel to improve element quality in a surface-based mesh or a mesh of solid elements using one or more algorithms that adjust node positions to moderate sharp variations in size or quality in adjacent elements.
    • Smooth Particle Hydrodynamics Panel
      Use the Smooth Particle Hydrodynamics panel to perform SPH analysis on a component with volume, such as airbags or fuel tanks.
    • Solid Edit Panel
      Use the Solid Edit panel to modify solid entities.
    • Solid Map Panel
      Use the Solid Map panel to create a mesh of solid elements in a solid geometric volume.
    • Solid Mesh Panel
      Use the Solid Mesh panel to create meshes in a pentagonal or hexagonal volume defined with edge lines.
    • Solids Panel
      Use the Solids panel to create solid geometry using a wide variety of methods.
    • Solver Panel
      Use the Solver panel to run an external program from within Engineering Solutions or assign and run a solver on selected analysis decks.
    • Spheres Panel
      Use the Spheres panel to create a spherical surface and/or mesh.
    • Spherical Clipping Panel
      Use the Spherical Clipping panel to focus on specific areas of the model by displaying only the portions of a model inside a three-dimensional spherical volume, while masking everything outside the sphere.
    • Spin Panel
      Use the Spin panel to create a surface and/or mesh or elements by spinning a series of nodes, a line or lines, or a group of elements about a vector to create a circular structure.
    • Spline Panel
      Use the Spline panel to create a shell mesh and/or surface. A mesh and surface can be created using nodes, points, or lines. You can also use the Spline panel to create a mesh without a surface, or a surface without a mesh.
    • Split Panel
      Use the Split panel to split plates or solid elements. In addition, hexa elements can also be split using a technique that moves progressively through a row of elements in the model.
    • Spotweld Panel
      Use the Spotweld panel to create 1D elements to connect different parts.
    • Springs Panel
      Use the Springs panel to create spring elements.
    • Summary Panel
      Use the Summary panel to obtain a summary of component element counts or element properties of the current model.
    • Super Elems Panel
      Use the Super Elems panel to assign nodes to a super element set. You can also display the nodes that belong to a super element.
    • Surface Edit Panel
      Use the Surface Edit panel to perform a variety of surface editing, trimming, and creation functions. This panel also allows you to offset surfaces in their normal direction.
    • Surface Transparency Panel
      Use the Surface Transparency panel to set the transparency level for the surfaces of selected components.
    • Surfaces Panel
      Use the Surfaces panel to create surfaces using a wide variety of methods.
    • System Collectors Panel
      Use the Systems Collectors panel to create and update system collectors.
    • Systems Panel
      Use the Systems panel to create rectangular, cylindrical and spherical coordinate systems. Use this function when you want to define nodes, loads and constraints in a different coordinate system.
    • Table Entries Panel
      Use the Table Entries panel to specify table entries for use in equations for responses and design properties.
    • Tags Panel
      Use the Tags panel to assign names to nodes, elements, lines, surfaces, points, and solids. An entity name is then used to reference the entity across multiple versions of the same model.
    • Temp Nodes Panel
      Use the Temp Nodes panel to control which nodes are on the temporary node mark.
    • Temperatures Panel
      Use the Temperatures panel to create temperature constraints.
    • Tetramesh Panel
      Use the Tetramesh panel to fill an enclosed volume with first or second order tetrahedral elements.
    • Titles Panel
      Use the Titles panel to create, edit, and move screen titles and entity tags.
    • Topography Panel
      Use the Topography panel to define design domains for topography optimization.
    • Topology Panel
      Use the Topology panel to define design domains for topology optimization.
    • Torus Panel
      Use the Torus panel to create an analytic, toroidal surface and/or mesh.
    • Transient Panel
      Use the Transient panel to create an animation sequence from transient results.
    • Translate Panel
      Use the Translate panel to move entities in a single specified direction.
    • True View Panel
      Use the True View panel to change the current view of your model based on a model vector or angles.
    • Vector Collectors Panel
      Use the Vectors Collectors panel to create and update vector collectors.
    • Vector Plot Panel
      Use the Vector Plot panel to create analysis-based vector plots.
    • Vectors Panel
      Use the Vectors panel to create a vector entity.
    • Velocities Panel
      Use the Velocities panel to create concentrated velocities.
    • Window Panel
      Use the Window panel to control xy plot window size and placement.
    • XY Plots Panel
      Use the XY Plots panel to access the XY Plotting panels.
  • Geometry
  • Meshing
  • Connectors
  • Model Setup
  • Morphing
  • Optimization
    Setup an Optimization in Engineering Solutions.
  • XY Plotting
View All Altair Simulation Help
2022
  1. Home
  2. ...
    • Panels
  3. Safety Module
  • What's New
  • Get Started
  • Tutorials
  • NVH
  • Crash
  • CFD
  • Aerospace
  • CAD Interfaces
  • Browsers
  • Panels
  • Geometry
  • Meshing
  • Connectors
  • Model Setup
  • Morphing
  • Optimization
  • XY Plotting
Index
ON THIS PAGE
    Safety Module
    • Masses Panel
    • Assemblies Panel
    • Blocks Panel
    • Control Vol Panel
    • Dummy Panel
    • Elem Types Panel
    • Ellipsoids Panel
    • Entity Sets Panel
    • FE Joints Panel
    • Interfaces Panel
    • Joints Panel
    • MBS Joints Panel
    • MBS Planes Panel
    • Organize Panel
    • Penetration Panel
    • Rename Panel
    • Rigid Walls Panel
    • Sensors Panel
    • Systems Panel
    ON THIS PAGE
