Window Panel
Use the Window panel to control xy plot window size and placement.
Panel Options
Option Action
color override Override the currently assigned curve colors.
display legend Display the legend.
display simulation title Control the display of the simulation title.
plot Select the plot to edit.
resize Resize a window by selecting a corner inside the window of the plot, holding down the mouse button, and moving the mouse.
move Move a window by selecting a point inside the window of an xy plot to be relocated, holding down the mouse button, and dragging the window to its new position.
pop Bring a window forward to the front of a stack of windows.
push Place a window on the bottom of a stack of windows.
stack Stack the windows in the upper corner of the screen. This function resizes the windows during the process of stacking.
unstack Subdivide the screen and place each displayed window in one of these subdivisions. After this function is complete, the xy plots cover the graphics region of the screen.
expand Enlarge a selected xy plot so that it covers the entire graphics region of the screen.
find curves Determine the minimum and maximum values necessary to display all the curves on that plot. The plot ranges are set to that range.
circle zoom Zoom in on an area of your xy plot.
move legend Relocate the legend.
