Assemblies Panel
Use the Assemblies panel to create and modify assemblies, which are collections of component and multibody collectors or other assemblies. This method of grouping component and multibody collectors is useful because once an assembly is created, it is possible to display components or multibodies by assembly, or to select entities by assembly rather than by component.
Card Image Subpanel Options
Option Action
assem name= Enter the name of the assembly, or click assem name= to select an existing assembly.
card image= Enter the name of the card image, or click card image= to select an existing card image.
Card Image Subpanel Command Buttons
Button Action
Load Load the selected assembly and card image.
Load/Edit Load and edit the selected assembly and card image.
Edit Edit the selected assembly and card image.
Reset Reset the current field to its original value.
Reset All Reset all fields to their original values.
Create Subpanel Options
Option Action
comps Select the component(s) to include in the assembly.
assems Select previously defined assemblies to include in the assembly.
multibodies Select previously defined multibodies to include in the assembly.
color Select a color for the assembly
Create Subpanel Command Buttons
Button Action
Create Create the assembly and card image.
Create/Edit Create and edit the assembly and card image.
Update Update the assembly and card image with changed information.
Review Review changes made to the assembly and card image.
